Intake for 4V = 1000RWHP ... just thinking aloud and planning ahead..
1685 Views 24 Replies 4 Participants Last post by  KEVINS
Swapping my 2v induction for 4v induction has me thinking a bit about hood clearance. Currently I was using a Vic Jr with a 6061 elbow and 90mm TB and this juuuuuussst cleared the hood:
Hood Automotive design Motor vehicle Vehicle Automotive fuel system
Now with the 4V induction soon to come I was thinking about a Sullivan intake with some sort of elbow to hopefully keep my existing TB but I'm fearing that setup is taller with the 4V heads. If it is then I need a backup plan. The Sullivan is listed at 4.5" tall and the Vic Jr measures the same...
If I don't go with a Sullivan intake is there another intake that may work that will flow enough for the HP I'm looking for (1300FWHP)? It needs to be a side entry. I was even thinking of gutting the inside of a Cobra intake and welding tubes or ?? on the inside to make it look stock but able to flow more. There are major issues with this idea since air distribution would need to be correct unless someone has already done it and proved it out..
If not a Sullivan anything else I should look at? I can fab about anything so modifying something is acceptable.
Again, just thinking and planning, dreaming...
ks
See less See more
  • Like
Reactions: 1
1 - 20 of 25 Posts
2
I just saw this vid with a 8 second 4V with this intake.. What does one of these need to flow that much HP anything special?
Vehicle Hood Car Motor vehicle Automotive fuel system
See less See more
Kevin,
The short way home with excellent fit and support for all things like IAC valves, PCV etc is the factory Cobra n/a manifold you show in the pic above. Everything fits and hood clearance is excellent, even with a spacer like in the picture. Power is not bad either, although he doesn't say what boost he is running. As big a factor as manifold flow is intercooler heat sinking capability. When you run the kinds of boost you have and I suspect will do again, there is a lot of heat to be pulled out of the intake charge. I am presuming you already have a significant IC capability.
The next step after this would be a fabricated manifold. I would give Shelby Mike a call and ask for his help with the intake flanges. He has all the data for his own billet manifolds and just might whhip up a set of flanges for you to build a welded manifold. Intake runners are just straight tubes squeezed to oval on one end. the plenum is similar, i.e. a round tube squeezed into an oval form and welded to the intake tubes with a billet throttle body plate welded to the front and a back welded to the plenum to seal it up. This is Mikes webpage => https://www.shelbymikeracing.com/
See less See more
  • Like
Reactions: 2
Ah, I never saw the spacer under the lid...There are plenty used ones available, too.
Specs of my Treadstone IC are dual 2.5" inlets and a 3.5" outlet
IAT's on the high boost pulls were 130* with 80* ambient air temp
Pressure drop on the 39psi was 1.3psi
Edit:
Crap I just saw what the bottom portion of that intake looks like and there is some large square box under it which won't work on my car b/c I have a wire tuck and ALL the gazillion wires including for the Safe Guard wires are packed under the intake..
Automotive tire Bumper Gas Rim Automotive lighting
ks
See less See more
Kevin,
In stock form there is still a good amount of room under the stock intake but I can see it filling up quickly with additional wiring. It is a common practice to cut open and port/ shorten the runners on these intakes. In doing so some of the builders will weld an aluminum plate on the bottom to raise the lower intake floor. Never Enuff Performance Racing on facebook has an excellent picture tutorial on one of their intakes being modified as well as other in process intake modifications. The raising of the manifold floor may give you the added clearance that you need for your additional wiring.
  • Like
Reactions: 2
Kevin,
Thank You, I will see what I can find on the modification. I saw an image where someone cut apart the inner tubes on the "other" type of Cobra intake and it looked awful and I doubt the flow between cylinders would be even.
Fabbing intakes is a complicated process, more than most people realize. Here is a thread where people are attempting to do such a thing and there are a lot of interesting concepts that didn't work but a few that did.
The general concept is pretty basic the hard part is fitting the design into a small package.
ks
Kevin, here is a YouTube video by Richard Holdner on a handmade intake fabrication project. Richard started with straight intake tubes he could easily change the length of until he got to what the engine liked. Once he found what the engine liked he fabbed up a much more compact version. Sort of your observation. Good read/view but — lots of work. Click here => Richard Holdner on Intakes
BTW the differences from best to worst are worth evaluating ...
  • Like
Reactions: 1
I've seen Richard Holdners vid before and they are educational, a lot of theories put to the test with good technical results. I loved his idea for adjustable runner lengths. I could have a blast doing things like that if I had resources...
While I am waiting for used 4V heads to be shipped to me can someone tell me if the distance shown in the pic below between the 2V heads are the same as 4V heads? If they are I can move forward on collecting data on intake heights.
Motor vehicle Automotive tire Automotive design Automotive exterior Automotive lighting
ks
See less See more
The 4V heads are wider than the 2V heads, which should make the intake port gasket surface both higher and closer together, bank to bank, than the 2V equivalent I believe, Kevin.
I received the Mach 1 intake and there is no way I can get the intake on with all the wiring from the Safeguard so, alas, I am seriously pondering removing the Safeguard completely. I hate to do it but the car is only run on E85 but I'm not happy about loosing this high tech piece of safety. I'm going to take a good hard look at the wiring this week to see what it would take to hard wire it all on instead of using the PnP harness but it is a rats nest of wires and it may be coming off.
I've also been studying removing the divider then how to blend the opening to an elliptical TB. The casting is really thin at the edges where the elliptical opening needs to be cut away so I may make a spacer to go from an elliptical opening (TB) to an oval opening (manifold). Still thinking....
Fuel Rails: I was hoping that my existing fuel rails would work with some modifications but not going to happen so I ordered a set that is supposed to fit...bummed.
ks
... I've also been studying removing the divider then how to blend the opening to an elliptical TB. The casting is really thin at the edges where the elliptical opening needs to be cut away so I may make a spacer to go from an elliptical opening (TB) to an oval opening (manifold). Still thinking ...
Your observation about the thin casting sections, when you machine out the divider for the OEM two-bladed TB design, is spot on, Kevin. There is insufficient material present in the OEM casting to allow the machining operation to directly support the elliptical TB you are wanting to use. The correct and best way out of the dilemma is the use of a half-inch or three-quarter-inch thick spacer that blends the elliptical throttle body shape to the flat top and flat bottom-sided oval that you will have after machining out the divider for the two-bladed OEM throttle body.
The three-quarter-inch thick spacer will give you additional space to smoothly blend from the elliptical to the flat top and flat bottom-sided oval that you will have after machining out the throat of the OEM two-bladed throttle body mounting flange. You will probably need access to, or buy spindle time on a five-axis CNC mill to do the job, but if you choose to go that route, it will be very difficult to improve upon your finished solution.
BTW check out eBay (I know, I know); you will find any number of elliptically bladed throttle bodies in near new condition in the $300 range instead of the $600 brand-new price range. That will give you additional monies to throw at the elliptical to oval TB adapter.
See less See more
  • Like
Reactions: 1
I get a kick out of the intercooler guys. We buy intercoolers to cool an incoming air charge from a compressor. To properly size the intercooler, we need to know its capacity for cooling. The number of inlets and the number of outlets are interesting but non-responsive to the inquiry about heat transfer capacity and transfer speed. While we certainly do not want an airflow restriction again, airflow is non-responsive to the inquiry about heat transfer capacity.
The interesting part of the problem is that they have engineers internal to their firms that use this very information to design the IC, yet they choose not to publish the data, and not to share the data with potential buyers who are attempting to "right size" their intercooler choice so they only need to purchase one time! This sort of behavior is like going to a supplier of fasteners to buy a bolt, and the fasteners have no sizing or thread pitch data available for the customer to make his selection — it is stupid in the extreme!
I suspect (I hope I am right) that if you could get to the engineering design crowd, they could provide the needed answers. It is just one more battle we need to wage to properly build one of these engines.
See less See more
  • Like
Reactions: 1
From a marketing point a view I would think that an IC core company could easier promote the quality of their cores if they published the efficiency and at the same time weed out the inferior parts in the market. If I had developed a great core I would certainly be promoting it with data.
ks
  • Like
Reactions: 1
2
Kevin,
A member on one of the modular Facebook groups posted this today and thought I would share. It is relevant to your iac issue as well as the intake height issue. You can see the short runner modification and how it raises the intake floor a decent amount from stock. It is also a very clean solution to the remote iac setup.
Motor vehicle Automotive tire Gas Auto part Engineering
Wood Sculpture Art Metal Monochrome
See less See more
  • Like
Reactions: 1
It was suggested that Bell Intercoolers (<= clicky) makes good cores so I am looking their cores over. I see that I can order just about any size I want and I have my eye on several so when I get more time I will look them over in detail.
ks
I have already talked to the engineering guys over at Bell. They talk engineer! Initially, the discussion started with the usual how much HP are we talking about dialog and I switched it to how much heat we are creating and how much we want to get rid of. The tone and the quality of information immediately took a step up and the individual at Bell asked me which company I worked for because he said the questioning was what he expected in an OEM engineering inquiry from one of their OEM customer's engineering team members.
Once you get past the how much horsepower issues then you can have a much more productive discussion. The two metrics that they will look for are charge temperature and mass flow. Here is the link to the Ideal Gas Law Calculator <=clickable. If the amount of substance molar value is problematic email me or give me a call and I'll help. One of Black2003Cobra's calculators will be quite helpful in determining pounds of air which is the other metric the engineers at Bell will ask for. Here is the link to the calculator => Volumetric and Mass Air Flow Calculator
See less See more
  • Like
Reactions: 2
Thanks Ed!
I'm juggling a lot of info on this swap keeping it all moving forward but I'm taking all your hard work in... Hopefully you're getting my PM's, too.
ks
  • Like
Reactions: 1
Once I get some time to do some calc's (I may need your assistance but will let you know) it will be interesting to see how big of a core will be needed. I took about 15 minutes last night to quickly CAD up an additional thought but I need to sit down and model up the front portion of the car so I can design around those problem areas.
ks
Thanks Ed!
ks
I am but was a bit tardy in replying to your last two. :(
  • Like
Reactions: 1
2
Getting back to calculations:
I modified Black2003Cobra's spreadsheet to allow more info on higher boost values. I do not expect to need more than 28psi if this engine build is efficient but I have seen some stock terminator gents running 32psi so I wanted to plan for that size IC if I can fit it. The values I am looking at are in RED in the below tables.
I'm not sure what values Bell will be asking for but the values I figure are below (feel free to correct me):
I figure 1400FWHP => 1100RWHP
What other info will they need?
Volume Flow rate: 1600CFM
Mass Air Flow: 120lb/min
Font Pattern Screenshot Parallel Rectangle
Font Pattern Number Screenshot Parallel
Given the Ideal Gas Law equation here are my unknowns:
  • P — Pressure, in pascal;
  • V — Volume in cubic meters;
  • n — Number of moles;
  • T — Temperature in kelvin; and
  • R — Ideal gas constant. (8.314)
I'm gonna need your help, Ed. I'm not sure what Bell will be solving for in order to determine core size. I'm guessing Volume.
I'm figuring ambient air temp to be around 90F but I'm not sure if the temp they are wanting is air temp before or after the IC or ambient temp, etc. Ideally air temp after the IC is the same as ambient..
KS
See less See more
1 - 20 of 25 Posts
