Swapping my 2v induction for 4v induction has me thinking a bit about hood clearance. Currently I was using a Vic Jr with a 6061 elbow and 90mm TB and this juuuuuussst cleared the hood:
Now with the 4V induction soon to come I was thinking about a Sullivan intake with some sort of elbow to hopefully keep my existing TB but I'm fearing that setup is taller with the 4V heads. If it is then I need a backup plan. The Sullivan is listed at 4.5" tall and the Vic Jr measures the same...
If I don't go with a Sullivan intake is there another intake that may work that will flow enough for the HP I'm looking for (1300FWHP)? It needs to be a side entry. I was even thinking of gutting the inside of a Cobra intake and welding tubes or ?? on the inside to make it look stock but able to flow more. There are
major issues with this idea since air distribution would need to be correct unless someone has already done it and proved it out..
If not a Sullivan anything else I should look at? I can fab about anything so modifying something is acceptable.
Again, just thinking and planning, dreaming...
ks
