I'm a decent welder, and wouldn't mind welding the tubes to the center section of my 8.8. Some people advise not to do it without a jig, while others claim to have cuccess without the use of a jig.
Would the jig be used to get the axle tubes straight prior to welding, or to KEEP it straight while applying the heat from welding?
Looking on other forums, people generally apply heat to the center section as it's thicker, prior to welding and divide each tube's circumference into six equal parts, then laying down a weld on every other section until you've gone all the way around, then do the same for the 3 remaining sections, with no cooling. Some even advise to torch the area afterwards to control the cooling to a slow, slow pace.
This sounds pretty easy with good metal prep and a bit of patience, anybody here use the DO-IT-YOURSELF approach? And if so, will this method work for me.
By the way, I've never once heard of a tube spinning in the housing, but I haven't looked real hard either, I just hope this isn't a huge waste of my time.
