1 - 20 of 23 Posts
What size pulley on a Jt-trim would give me about 20lbs of boost I am new to the Jt-trim and have many questions?
I will be purchasing a jt-trim in a little bit and will be running a 3.125 blower pulley with a bigger crank pulley. My goal eventually is 25psi. That is what I am starting with though.
Dave
see i am still on a stock shortblock so only want to go to about 20lbs, I think the 3.125 alone would be able to accomplish that. What are you using for pullies an 8 or 6rib?
Go ahead with the 8-rib Reichard 3.12 pulley! I am still running the stock computer.
jim has not made any 8 rib 3.1" vortech pulleys yet. i tried getting one last week. i had to settle for a 3.0" 8 rib pulley.
Chad has one, I've seen it!!!! LOL :evil
Slovobra--
I hope you plan on building your motor soon, as we put a D1 SC on a stock 97 4V motor and it lasted about 2 days before all the rods bent...It pushed about 20lbs through the motor on the STOCK pulley :shocked :shocked
You can get the rest of the 8 rib pullies off a F150 truck..including the tensioner...Try the junkyard first and then your ford dealer...
Jeff
SloVobra said:
where can I find the rest of the 8-rib setup? and what would I have to do cause I run no a/c?
One more thing dude, are you running the A/C eliminator kit from FMS??? If so, I have a custom ASP 8 rib idler pulley that goes on the Ford Motorsport A/C eliminator kit...It was custom made for the FMS setup...I'll sell it to you for $80....Its brand new in the box...
Jeff
actually the car pushes 20 now its tuned by lidio, right now where gonna try to be the fastest stock longblock car.
oh and motor is definately next trust me I already have one being built just want to see how far I can go. I mean the car is stock trans, stock rear end except for a 4.30 and it went 10.80 with a very moderate tune, do I will do the same with the Jt-trim, lidio in my eyes is the shit with these cars. The only thing am debating is the eight rib set-up I think I want to try it with a 6rib first I dont know.
Slovobra--
Jeff
jeff,
i thought chad was running a 2.95" 8 rib, reichard pulley?
Discussion Starter · #12 ·
black cobra i'll take it where do you live, I need that pulley thats the only one I was really worried about, does the 8rib crank pulley match up to my stock 6rib is it the same diameter??
slovobra,
i have a 6 rib 3.3" and 3.1" reichard racing pulley i can sell you. and, i also have 6 rib ati balancer i can sell you.
bryan, I thought chad had the 3.12 on there, I may be wrong then....I'm almost 99% sure its a 3.12 though...makes about 20lbs or so on my motor :evil :evil
Slovobra---Yeah Lidio is the man, he's helped me out alot in the past 4 years :D Good luck with your project....
I'm in northern va, outside of D.C... you can shoot me an email at [email protected] and we can work out the details...I take paypal at that address too....Its the same diameter as the 6 rib A/C eliminator pulley that FMS sells...It has the nice bearing in the pulley too, nice piece from ASP....It will slip right onto the FMS eliminator kit with no issues...Yeah, I had it custom made, cause that was the only 8 rib piece I needed...
thanks
Jeff
Slovobra--
One more thing, about the crank pulley...Get a SFI 8 rib balancer from INnovators West...They are NICE pieces and get the oversize one, I believe its a 7" version...I know they were working on a 7 1/4" version as well, but you have to grind off some of the front cover and the timing marks with that big of a crank pulley...Stock diameter on the 6 rib crank pulley is 6.75", so you will want at least a 7" crank pulley to allow you to get better belt wrap and more boost too :evil :evil
Jeff
What mods are done to the longblock and what did the car dyno ?
Have you weighed the car ?
take care
Brian Bradford
98 Cobra
603rwhp/499 rwtq
Stock longblock intake to oil pan
10.46 @ 133 with a 6.71 in the 1/8
Best 1/8 6.52 @ 106 and blew the clutch out again
Discussion Starter · #19 ·
my car is a 97 its is absolutely untounched not even a throttle body
552rwhp/420rwtq
I do have alot less suspension than you though I have stock k-member, etc. car weighed about 3450 with me in it
best 1/4 mile was a [email protected] with a 1.67 60ft. car doesn't like to hook I currently am working on the suspension a great deal to try and get a 60ft of 1.4-1.50s by the mph etc car should run about the same as yours, I would lthink your car would be alot faster than a 10.49 you weigh a hell of a lot less than i do and 50 more rwhp, do you have a safe tune on the car?
My car weighs 3552 lbs , seems you have done some weight reduction ? What was you 1/8 ET and MPH ?Temperature,Barometric Pressure and humidity . On the pass when it ran a 10.46 it was making 558 rwhp and 445 rwtq, the temp was 81 degrees,68 percent humidity,30.02 Barametric pressure . It sucks down in the south
On my best 1/8 mile pass my clutch exploded in fourth gear and it ran a 6.52 @ 106 in the 1/8 which equates to a 10.20 or so pass @ 137-138 range , I was running the SPEC stage 3 clutch with heavy ass TKO tranny
a/f is under 12.0 through 7000 then starts to lean out
We are in the process of putting a PA Supercomp C4 in it now and looking for 9.90-10.10's if the stock motor holds up. The car has over 300 passes on it and 97 10 second passes
1 - 20 of 23 Posts
