1 - 6 of 6 Posts
Like the title says. Can I just instal k member without the coilover kit? My car is a DD and maybe I will take it to the track once this year.
yes just make sure you get a k member that will accept stock a-arms and has spring perches. YOu can also run tubular a-arms instead of the stock ones as long as they have spring perches and k member has spring perches. It's usually an option when you purchase the kits
doing it with a 2v..
Pa racing is whe way to go with something like this.. Just make sure you dont put isolaters in when you reinstall the springs because if you do it raises the car a bit.
Sounds good. Thank you!!
no problem.. I ran thier kmember and stock springs and a arms for a long time... love it, helped weight transfer a ton, and rode just fine esspecially compared to how it rides now with the a arms, coilovers, lakewoods, and kmember spacer.
1 - 6 of 6 Posts
