1 - 5 of 5 Posts
Anyone using the KB BAS? They recommend a stock plug gap, what do you guys think?
They also recommend setting it at 30% initially.
Any help that you all could offer with the install would be greatly appreciated. The instructions are not so hot.
Grover
What Plugs are you running ? I have a BAS and running IT-24s with 20lbs boost. Before the BAS I was getting spark blowout above 5000 rpm with plugs gapped to .028-.030 Now I have opened them up to around .035 with zero problems. Depending on Boost level and plug type i am not sure you see much of a performance gain rather an aide to increase the boost without "flameout" Just my experience and .02 cents worth.
Jon L :)
Hey Jon, thanks for the reply. I am running the NGK TR6's at .035.
Getting blowout at >6200rpm with anywhere from 16-19lb boost (depending on the combo).
KB says gap them at .042, sounds too big to me.
Mark
Jon, what do you have your BAS set at?
Not necessarily looking for performance gain, actually not really sure what to expect!!
Mark
1 - 5 of 5 Posts
