Anyone know what length to run with the KB with a 3" , Metco auxillary idler w/90mm pulley and a Metco 8lb lower. Trying a new setup. Any ball park suggestions would be great.
my 81" upper barely fits with an 11# upper, 6# lower, & 90mm idlers + aux.
hope that helps.
KB Belt
I run a 3.25" upper and a 8lb. lower with a 82.5" belt and 90mm aux + idlers. I have both 90mm & 100mm pulleys to get the correct length required to work. I beleive a 81.5" belt will work with the 3" upper. You can change the lower Metco idler also to get the correct length. I also ground off a little of the tenchner to get more play to put the belt on.
AMB
