1 - 5 of 5 Posts
i am putting the bottom end of a 96 lincoln in my 99 cobra, i bought the car in peices and im trying to put this jigsaw back together, the knock sensors for the lincoln are different than the ones for the cobra can anyone tell me how to fix this???
Easy, don't use them. You don't HAVE to run them. Most of not all SC/Turbo stangs have them disabled, most focus/escort guys first mod us to disable it. Long as you have a good tune, your fine.
I found that if i heli coil the stock mark viii knock holes...ill be able to bolt my stock cobra ones to that block..does the tapered end look up or down? I cant remember...also as long as its bolted to the mark block in the same manner it should work right>?
1 - 5 of 5 Posts
