When I was running slicks, I would disconnect th front sway bar, launch it off the limiter at about 6200 and it would dead hook every time. Once, I forgot to pull the bar and it spun like mad. The slicks are gone because this is a daily driver and it still has stock axles.
ANYWAY, on my street tires, this is backwards, my best 60' is with the bar in, What gives??:confused:
Also I just picked up some 26X10 M/T Sportsman Pros and I can't even break 2.00 60's with various PSI adjustments. My best on my comp T/A 245/45/17's 2.07!!! You would think this drag compound tire would show more of an improvement. They also feel unstable at the top end, also after 1000ft, MPH seems to fall off. None of this was the case with the same size ET drag with less PSI.:confused: :confused:
Anybody had any success with these tires?
Figured them out. 13.44, 1.9 60'. Not spectacular but 3 tenths improvement with exact same setup.
