Lentech Strip Terminator w9.5" Converter
1271 Views 6 Replies 4 Participants Last post by  Ninesecsnake
I have a Lentech Strip Terminator transmission w/manual valve body and every option that he offers, including some that he doesn't, OD and his third first technology. I have a transmission case for a modular or a Windsor based motor as well as a flex plate shield, just tell me what motor you have and I will have Len assemble it in that case.
The transmission is currently on its way to Len at Lentech to be completely overhauled and made new again, it didn't have many miles on it but I want to make sure that it's 110% before I sell it to anyone. Then it will be shipped from him to the new owner.
The converter is a 9.5" steel stator that Len sells, it flashed to 3400 behind my twin 61mm 5.4 modular motor. This transmission has been [email protected] on a 275 radial tire in my 3800lb car. I would say that if you make under 1200wheel and are 3700lbs or less this transmission will last forever.
I would like to get $3500 for the whole package, it's going to cost me $995 to have Len go through the whole transmission, but like I said above I want to make sure its 100% ready to go.
I am open to offers but I don't need to sell it so I'm not going to give a $6000 transmission away.
Thank you,
Ryan
[email protected]
605.413.3097
1 - 7 of 7 Posts
interested in the Transmission
Do you have a spec sheet on the transmission? What vehicle was it in? I'm wanting to go automatic in my 2004 tt cobra and was curious what other parts you may have. Could you take 3k for the transmission, flexplate, convertor, shield shipped to 70508. I could paypal you as soon as I check out the specs on the transmission. Obviously I'd need to go modular.
I could see if I could get one from Len, its his highest HP 4r70w that he builds, it has a manual valve body with trans brake, overdrive, his power flow modification (third,first), and its a non-lock up. I had this transmission in my 93 Cobra behind a twin 76mm dohc 5.4, the most we made with trans and converter was 1180 wheel at 24lbs. I switched to a powerglide and no longer have anything to put this transmission into.
I would do everything shipped to you for $3500.
Thank you,
Ryan
just out of curiosity, would you be interested in trading for a built tko 500 with a blowproof bellhousing with a spec stage three clutch and aluminum flywheel and some cash? let me know if you may be interested. thanks
I'm sorry the transmission is sold. Thank you.
1 - 7 of 7 Posts
