1 - 16 of 16 Posts
Hey guys,
Now that the injectors are getting out, I was wondering what the people who have them in there cars think about them.
I am most interested in drivability. What are you all seeing.
For those who have them and have dynoed there cars, what kind of HP did you make?
If you used nitrous, was it a wet or dry kit?
Alan
hey Alan i got the 55lb injectors put in my car. I also run a Dry NOS System. I wasn't able to get to the dyno yet, but as soon as I do I will post everything. Besides that, the car runs awesome.
Matt
Pushrod Dinosaur
Ill have the 55's in my car next week. Will let you know.
gary
Once you get to around 500rwhp I feel they become necessary. How you do it really doesnt matter. The KB's appear to get the 03 Cobras up to 500rwhp in a Hurry. :D
thanks for the quick reply, Alan
I'm just trying to plan out what my initial investment will be if I take the KB plunge....
What's the difference between the high and the low impedence injectors? ...besides about a hundred bucks.
Pushrod Dinosaur
the impedence.
LMAO sorry............had to do it.......
gary
SVTyballz said:
the impedence.
gary
:rolleyes: Okay....NEXT!
...actually that WAS funny. :)
Alan, I am using your 55's in all the KB blower cars and the throttle response and power are awesome! The tunes are right on for them. These guys should be listing them in their mod signatures soon.
Thank you for your courtesy and expertise!
Peace,
Pete
Discussion Starter · #12 ·
A very basic answer as far as the impedence.
The difference in is the coil of the injector. It is the amount of current it take to fire the injector. A low impedence injector can react quicker. This is why the biggest High imp injectors are 50-55#. Anything bigger than that would have a hard time with drivabilty, throttle response, and WOT.
Most all Ford products require a High impedence injector. If you put a low impedence inj in a car that requires high imp injectors, it will usually burn up the inj drivers.
I hope this helps.
Senior Member
They work awesome Alan! The car was very easy to tune. Idled fine without loading up.Throttle responce at low rpm was good and no surging at cruise. Thanks for an excellent product, it makes my job easier.
Rick
I hope this helps.
EXCELLENT! Thanks for the info. However this leads to another question: would it be worth while for some kind of conversion kit to low impedance 55lb injectors?
Discussion Starter · #15 ·
Not to go to 55's it wouldnt, the high imp 55's are working out fine. To the best of my knowledge the cheapest low imp inj driver is around $375.
If you needed 72s it would be worth the extra expense.
At that point I think a 2 gallon gas can, poured directly into the port for each cylinder, would be more appropriate. ;-)
Thanks! :)
1 - 16 of 16 Posts
