Hi,
I am having some problems with my new motor. I have a 96 cobra with 01 heads and intake and a V7 YSI blower. I got the car running and took it to the dyno a couple of mounths ago and the car ran good. I started getting alot of blow by out of the filters on the valve covers. Over the weekand I lost compression on all cylinders. So I dropped some oil into the cylinders and did a compression test and got compression back up to 150-180 lbs per cylinder.
Has anyone had this happen to them. I have been thinking about some reasons why I would loose compression.
1: Rings didn't seat properly. I ran the car on the dyno to break it in. I didn't have any blow by at the beginning. The blow started to gradually get worse over the weekand after I took it for a 45 minute drive.
2. Not pulling enough vacuum out of the crankcase which cause the boost to blow the fuel past the rings causing the washed cylinders. This seems like a problem because I only have filters ontop of the valve covers and I am not using my crankcase vacuum pump to pull vacuum. So I am thinking about installing new pumps.
3. Cam timing is off and leaving the valves open. This could be I am looking into this a little more still. I did degree the crower stage 3 cams. I believe I degreed the intake to 110 and the exhaust to 118 and 118.5.
If anyone could give some input that would be great.
Mark
Mark
