1 - 20 of 24 Posts
just looking to see who is running what alternator pulley w/ what lower. my first lower was a 6# and the alt went out a couple weeks later 100 miles from home. then swapped the the 4# and its been fine for 3 years w/ a 3.2 alt pulley. some have said it was just coincidence w/ my bad stock alt.
so...
what lower?
what alt?
how long been running the setup?
I want to try a 6# lower again but dont know if I should keep the 3.2 or swap to the next one up on the alt.
Blower Whine Junkie
I ran no alt pulley with my 4lb lower for a year with no problems. Honestly the only reason I swapped to a 3.2" was because my battery was dead and I decided since I was pulling the alternator to check it anyway I'd swap the pulleys. I think Dwight ran his 4lb for a long time without an alternator pulley.
un1230/Whipple3.4/ Teksid
I run a 130mm alt pulley with my 6lb lower cog belt system
mofasta
I am running a 6lb with a 3.7 Alt I think. I twas the same one that I had when i ran an 8lb with stock upper.
3.2 alt here, with 4lb. been that way for about 3 months and 2500miles. no issues as of yet.
Yeah, I did a 4 lb llower with stock alt pulley for 14,000 miles and have been running a 6 lber with a 3.2 for another 8,000 or so now. Have about 34,000 on original alternator.....Knock on wood!
what is everyone's voltages hanging at while cruising around during the day and at night with headlights on? Just want to get an idea.
seems like everyone is all over the place...lol....I guess Ill just try it on the 3.2 and see what happens.
6lbs lower with a 3.5 Alt. when I had the Eaton!
10lbs lower with a 3.9 Alt. when I had the KB!
KK
I run a 3.2 with my 4# lower. With the alternator being as shitty as it is, i figured it couldn't hurt.
L&M build in progress!
3 & 4# lowers/ 2.76 for 45K. No issues. Still on stock alt, alt pulley and stock battery. I'm sure they will go out now that I said that out loud.
When I had my 6# lower on I ran the one size bigger than suggested pulley size. The 3.7".
I sold the lower but I still have the alternator pulley if anyone needs one.
Stock Lower=2.6 Alt Pulley
2 Lbs Lower =3.0 Alt Pulley
4 Lbs Lower =3.2 Alt Pulley
6 Lbs Lower =3.5 Alt Pulley
8 Lbs Lower =3.7 Alt Pulley
I ran a 3.2 with my 8lb lower for about 2 years when my alt took a dump. I run a 3.5alt now with 8lb lower, simply because with my 3.5upper/8lblower/3.5 alt pulley, the belt sizes jump way too much. I currently use a 83in belt that fits perfect.. the next belt size up that I could fine was a 89in belt.. nothing inbetween. But this was about a year and a half ago.. my alt is still working. If it ain't broke, don't fix it.
what size belt should i get with 6lb lower 3.7 alt and 2.93 upper stock pulleys not 100mm's im thinkin 80in belt
http://www.metcomotorsports.com/supercharger_belt_length_recommendations.htm
1 - 20 of 24 Posts
