Sal is there an easy way to reduce weight without reducing functionality of the truck. Like you could take out the radio and the spare tire but it is at some expense like if you get a flat oh **it . Truck is so heavy nearly 5000 lbs any weight off is just faster truck. Do lighter weight wheels help for example?
This is what most guys do- remove spare and hitch, pull front sway bar, pull off tailgate, pull out pass seat, remove rear bumper and use roll pan, and lightweight rims. If you want to go more hardcore, you can put in lightweight seats, smaller battery, and some guys remove the X brace from the chassis under the bed. With a 150lb guy, all that can get you down to about 4300-4400 lbs.
Why is it that CHUBBY GUYS ask this all the time??.
diet coke and pie alamode :shootbird
jim v.
