The retention screws which bite down on the telescopic steel handle come loose with hard shifting, even after repeated applications of Loctite Tite’N for Bolts. This is the second time the screws have backed out. The problem is the play the telescopic shaft receives while housed in the aluminum handle. An application of epoxy or cold weld compound may be in order...
Just had to retighten mine too. I used some JB WELD epoxy on the round threaded part where it goes into the blue aluminum part. Don't think it will loosen now. I used the same stuff on a muzzle brake on an AK47, that was about 4000 rds ago and it ain't ever budged.:D
Ummmm, had mine in since september, with no issues. Mabye I should check....
