I am rebuilding my MMR 4.75 and don’t understand the thrust bearings. I spoke to MMR today about the 2 blue shims that are needed that go between the cap bearing and the main cap, 1 on each side. With the main cap torqued the shims are loose and seem like they will fall out. MMR said to dimple just the main cap in 3 spots on each side to keep the shims from moving. I feel like the shim AND the cap should be dimpled together to keep shims from moving. Has anyone installed them before. They are the Romeo block 2v bearings
