1 - 2 of 2 Posts
i have a 2002 roush 360r and am looking to build a motor for it. i found livernois makes a real tough looking stroker rotating assembly. what should i use for a block? i would like to go with a aluminum block, is there an aluminum block that all the stock accesories will bolt onto such as the pulley bridge and all that stuff.
"Do Work"
Why dont you just get your motor machined, buy a rotating assembly, heads, etc and go from there?
Lots of different options you can go with.
- Longblock, and swap all your accesories over.
- Shortblock, then purchase heads/cams. Or get yours ported and add cams.
- Machine your block, purchase rotating assembly, Heads/Cams.
1 - 2 of 2 Posts
