My car is not a daily driver; just under 24K miles but the heater core is out...again. This will be the 2nd one I have replaced. Testing the coolant shows now AC voltage so I assume there is no electrolysis going on. I have a head cooling mod and am running the outer plastic restrictor without the inner washer. I have read the TSB regarding this issure and I can only assume that since there is no AC voltage present, I either have a flow/pressure issue or I'm just the unluckiest guy in the world and got 2 bad heater cores (the original from the factory and then the one I just replaced 8K miles ago). Anyway, I researched this issue first time around and here I go again. Can anyone shed some light on what I need to look for this time around or what exactly the problem is? Heater core R&R ain't exactly a fun thing to spend a Saturday afternoon doing...over and over. Thanks for any help.
Jeff
Jeff
