Mustang Rear Control Arm Kit Tubular Stainless Steel 1979-1998 | CJ Pony Parts
This Stainless Steel Tubular Rear Control Arm Kit is for all 1979-1998 Mustangs and will replace the factory stamped steel arms, which tend to flex and deflect during spirited driving. This kit includes polyurethane bushings for improved performance and is made from T-304 Stainless Steel, which is then polished.
Begin installation by removing the wheels and rear shocks. Then, remove the bolts holding the sway bar to the control arm and lower the rear to lessen tension on the control arm and take out the springs. Remove the lower control arm and install the new one, and then move on to the upper control arm.
Complete this process on both sides, following Bill's instructions, and then reinstall the springs and rear sway bar. The last step is to grease the bushings, and your installation is complete in 2-3 hours.
See more Mustang Rear Control Arms from CJ Pony Parts:
Mustang Rear Control Arms | CJ Pony Parts
