1 - 20 of 22 Posts
More pic whoring...
Been working on it the past two weeks. Still have a couple things to do.
Before and After
awesome job man, I really like it a lot. I haven't been on top of this lately, but what are you going to do about the throttle cable?
Did you also encounter any other problems while installation?
Only problem is had to use a 1/4" drive with deep wall and extension to get the back bolt. For the throttle cable and cruise control we are getting the Lokar cables. BlownBlu97 sent his off to get mached up and I will get mine when his final is good. Not sure if I am redoing the CAI or not. I will also have to extend the wiring on the plug to the Throttle body and get an 03 GT IAC sensor.
Throttle cable not a big deal I guess, but I didn't know we had to lenghten wiring and purchase a Gt IAC sensor?
I was getting one for my whipple, this is why I asked.
The CAI doesn't look too bad. Did todd finish the cai's that were supposed to be for sale?
The wire lengthing and Throttle Body lengthing are for the single blade adapters only. If you do not get an adapter then you will not have this problem. I am not sure if he ever finished the CAI.
Im so jealous! I wish my engine bay looked like that!
have any impressions on the 80lb injectors yet? Install looks clean
Si vis pacem, para bellum
Install looks great man! Can't wait to see what it's going to do!
We have been working with Todd Berry to revise all the issues surrounding the throttle cable. When we are finished the Behemoth inlet will ship as a kit (inlet, IAC, CAI, Throttle cable bracket) which will allow for the use of factory throttle and cruise cables. The cold air intakes are available for anyone running a twin 75mm throttle body. Feel free to contact us for more information.
Are these not ordered through MPH anymore?
Godstang, can't wait to see how your car reacts with this!
Ken
Discussion Starter · #13 ·
I am running the reducer so I will still have to extend my cable more than the 75mm will.
Discussion Starter · #17 ·
how much clearance is there for the Fore rails?
Not sure but I think the CPR rails are physically bigger on the outside than the Fore rails so the Fore rails should have plenty of room. I am running CPR because Fore was not out at the time.
Lokar should have my TB cable tomorrow. What I did was measure the exposed cable between the calbe sheething and where it slips into the TB and the factory was 6.75" then when the Behemoth is mounted up with the spacer it is not 10.5". I sent them the whole cable so then can either replace the cable in my factory sheething with a longer cable or maybe create one with some adjustability.
I have fore fuel rails for my car so I will be able to show the difference between the CPR's godstang has and mine with the fore's.
Hey godstang I am going to go for the chrome bolts this weekend!
1 - 20 of 22 Posts
