Background
I recently rebuilt my motor and now there is loud tick coming from the bell housing and the back of the motor. When I built the motor I checked every tolerance completely. I followed the instructions in 2 different books, posts on this forum and the Ford shop manual as to how to assemble the motor. I can't believe the motor is screwed up, but I'm not ruling it out. Also, I installed a new stage 3 spec clutch.
Problem
The noise sounds like I'm running solid lifters, but its not coming from the cams. It's coming from the bottom of the motor. I actually hear it best on the bottom of the driver side of the bell housing about an inch in back of the dust shield. When I put a stethoscope on it, I can feel a vibration that correlates to the noise as well as hear it. I hear not only a ticking but scraping as well. That said, I also hear the noise at the back of the block. This is coming from the side of the oil pan between the 2 bolts closest to the transmission on the driver side of the car. I do not hear it when I touch the pan or pan bolts. I hear the noise when I put the stethoscope on the dog ear beside the pan that's part of the block. I think its there for the bell housing bolts to bolt the trans to the block. This noise is just a ticking noise. A tick like solid lifters. No scraping noise from the block like in the bell housing. The tick at the block is very clear. tick tick tick tick tick. Where the noise coming from the bell housing is more of a ticking scraping noise. I don't hear the noise on the passenger side of the block or bell housing. I don't hear anything coming from the block when i listen to the area of the oil pan between the back of the pan and the transmission dust shield. Specifically no sound coming from the pan right around the crank.
Here is a link to a 99 making the same noise.
One last note. The clutch seems to work fine. The car shifts the best it ever has. Its not smooth at the initial take off. It grabs hard, but acts great once I take off. Not sure if the initial grab is normal for Spec 3 or if its something related to the problem I'm having.
I have no idea what this is. If you do please help.
Problem
