1 - 5 of 5 Posts
Administrator
If you are coming from an auto you will need a clutch and flywheel. Auto trans vehicles typically had six-bolt flywheels. If you do, which is the most likely scenario, then you should not buy an eight bolt flywheel — it won't fit. Get a six-bolt clutch and flywheel assembly. The five speeds shifted nicely but do not have the strength of the T-56 6 speeds. You might want to consider the T-56 six-speed.
Administrator
Not if they have an automatic trans, and I have not seen any manual trans Navigators. If someone put one in, that's fine. The OP can easily check and take appropriate action when he looks at his crank flange.
1 - 5 of 5 Posts
