1 - 15 of 15 Posts
What one's should I get? What's the difference between weld in or bolt in.
I was looking at the Steeda Stage I kit for 99+ Cobra's. It comes with Camber/Caster plates, Springs, IRS bushings, and bolt in Subframe connectors.
But I know most say you want weld in. Well what are some good weld in ones? Something that won't hurt ground clearance.
thanks for the help.
maximum motorsports full length, or GLC which i hear are supposed to be good also.
You mean GRC. I have a set that I ordered, but due to my Cobra being in the body shop after being rear ended, I haven't installed them yet. I love Maximum Motorsport stuff, but these GRC subs are a great design.
MM subs are 1.25x2 inches with a .085 wall thickness. The GRC's are 1x2 inches with a .125 wall thickness. So they are at least equal in strength. But I love the way the GRC's step up closer to the body forward of the rear subframe. The clever design increases ground clearance.
See the subs at:
http://www.grcperformance.com/
The photo below is not mine, but shows the step design well.
Thats some nice welding:jawdrop :jawdrop Mad props to the welder.
Thanks for the info.
I went to the GRC site but like Hunter pointed out the parts section is down.
Maximum Motorsports subs are 1x2 x .120 thick. The full length subs are the mentioned .80" thick.
Then the other question is how much do you weld? The entire length of the bar?
I was at their site when I posted, must have gone down after that.
I myself do not believe in full length welding, although some do. I think there's nothing to be gained strength-wise, and you risk overheating problems. I believe in the one inch weld, and every 3-4 inches should be plenty.
...snip...
The difference is bolt-ins don't do squat.
I have MMFLSC's, very happy with them. Gave my car a noticeable improvement. Easy quick install at a local shop.
Lots of pics of them in my sig.
global west.......
they are truly the best ones.......tubular , lighter and stronger.......made of rollcage material.....full length, from the front of the subframe to the rear at the torque box....used these for over 10 years.......from street stuff to my own 8 second race car......none are better.....:shocked hermann
Re: global west.......
Link or picture?
I too have used Global west sub-frames they are very nice. They have been on 1990 mustang for years and hold up great. And I plan on using them again on the cobra. www.globalwest.net
Mac is going to make 03 subframe connectors really soon. They are very similar to the Global West SFC's.
1 - 15 of 15 Posts
