1 - 6 of 6 Posts
I'm try to remove the mirrors on my 2000 saleen,and i'm unsure how to get the mach 460 speaker & cover , at the top of the door, out of the way. Any help would be appreciated. THANKS!!!
the grill is held in place by a sticky substance, it will just pull off and give you access to every nut and bolt you will need to sort it out.
take a flathead screwdriver and pop the cover off, just be gentle so you don't bend it. then there are 3 nuts that have to be loosened up and removed and then the mirrors slide out, the real PITA part is getting your hand between the door to unclip the harness...took me a bit but I got it when I swapped my 03 cobra mirrors on.
1 - 6 of 6 Posts
