I am installing a boost guage and a water temp guage. The boost guage seems straight forward. I need help with the water temp. guage. I need to screw in a sensor to register the water temperature. There is a brass fitting. Jegs said there should be at least one place on the engine that has a blank plug that you remove and screw in the sensor. Any ideas? Thanks. It is an electronic temp. guage.
This is a generic response to keep your question at the top :)
Have you looked at the thermostat housing? Sometimes people use this simply because you can easily take it off, drill it and tap it. I'm sure someone can give you cobra-specific advice.
Bill
i used the plug on the black pipe that runs beside the blower. Used some pipe sealant and voila! SVTOA sells a fitting is for an aftermarket water temp sender that goes in that black pipe.
