Hey Guys,
I've come to this forum many times over the years and gathered a lot of really useful information. So first of all, thank you.
Second, I've just started a new project of swapping an aluminum block 4.6 3V into my 2V New Edge GT. My reasons for choosing the 3V basically boiled down to weight. I've gotten into track driving and these things are very nose heavy. The understeer is awful. I did coilovers up front, v6 sway bar, Dunlop Direzza ZIII's (255/40r17) and it helped a little, but it still doesn't like to turn. So the idea is to make this car into a track toy, get it going around corners much better and end up with about 340rwhp.
The 3V, from what I can find will save me about 100# off the nose of the car. Plus the weight savings of the MM K-member and A-Arms, and relocating the battery. And the fact that the k-member will fix my front roll center, it should turn a whole lot better. I will also be fabricating my own Panhard bar, though I cannot afford to go the torque arm/adjustable sway bar/coilovers route at this time, it should help tremendously in getting the rear roll center down lower and keeping the axle from shifting side to side in cornering loads.
Another reason for doing to 3V is that with a little tuning, locking out the phasers, and a few small mods to the wiring, this engine will run on the 2V ECU. So it makes it a really straight forward swap in that regard. It will require cutting a hole in the hood or buying a cowl hood, which adds some expense to the project. But these engines are pretty cheap at this point. I picked mine up for $750 with 106k on it. I later found the cams were scored up and one rod was bent, but we'll get to that.
Anyway, here is the car.
When I bought the car, the engine had just been replaced with a remanufactured long block. With all the bolt-ons and a tune it put down 242rwhp. Fun for burnouts and enough power to get me started, but I'm ready for more at the track.
I found the motor on marketplace. Already out of the car, but he had a video of a cold start and it sounded good. So, I went for it.
I ordered up my cams and started to tear into the motor. I knew I was going to be putting a Melling oil pump in it, so the valve covers, front cover and oil pump came off. Here's what I found...
One head looked like a 100,000 mile situation inside, the other looked new. At that point I knew something was not mentioned and that the 'timing set replacement' that was done 6,000 miles ago was more than that. It was a whole cylinder head- for reasons unknown. And down in the oil pan, blocking up the oil pickup, was a valve keeper and remnants of the old chain guides.
Where 3V's are concerned, I'm not sure what goes first, the oil pump or internals which contaminate the oil and take out the oil pump. Either way, this baby was shot. Oh well, I planned on replacing the pump anyway. Let's get the cams out and keep moving forward.
Upon removal of the caps, I found major scoring of pretty much all the cam journals and towers. Lobes and followers looked okay, surprisingly, as the followers are also a common failure. Nevertheless, these heads were trash. So, again, headed to market place and luckily found a set 40 minutes from my house with 55k miles on them. An unplanned expense, but thats how these things go, right?
When I saw the condition of the oil pump and the top end, I figured it'd be wise to get a closer look at the bottom end. Since the bolts are TTY, I didn't want to take the whole thing apart if I didn't have to, so I was going to check one rod and see how it looked. Luckily for me, I pulled the #1 rod apart and it just happened to be the only rod in the engine that was bent. I had no suspicions of a bent rod, and it is by pure luck that I found this. I've purchased and used plenty of used engines in my life, none have gone this poorly.
Here you can see the bent rod.
The block is bare and I've started removing the flashing and sharp spots in the skirt. The cylinders measure good for size with no taper or out-of-round, and the cross-hatch is still there. I'm going to run a ball-hone through it lightly and run it.
And that's pretty much where I stand with it now. The plan is a very budget overhaul just to get it back on the road/track for the season...
That's the plan so far. I'll share more about what else will be happening to the car itself in later posts. Thanks for reading!
Brad
- Order new OEM rods (very cheap)
- Turn the crank .010" under (it is scored and at the bottom end of rod journal spec)
- New hypereutectic, coated pistons from ModMax.
- GT500 Oil Pump. (Tray and oil pan if nothing else comes up)
- The valves all mic out good and the guides are fine as well, so I'll just be doing a quick cleanup and fine lap to touch up the seats.
- PAC 300# valve springs
- 127500 Comp Cams (phaser lockouts)
- I'll balance the rods, weight match the rods and piston assemblies, then have the rotating assembly dynamically balanced.
Brad
