New Products & Specials from Ford Racing
1436 Views 0 Replies 1 Participant Last post by  Holcomb Motorsports
6
IMG]http://i206.photobucket.com/albums/bb234/saltnbattery1642/FRPP.jpg[/IMG]
MUSTANG BRAKE LINE KIT
Part # M-2078-MB
• Fits 2012 Mustang Boss 302
• Low expansion rubber lines
• Improves brake pedal feel
• Front and rear lines included
BOSS 302R VALVE SPRING KIT
Part # M-6513-M50BR
• Valve spring used on 2012
Mustang Boss 302 engine
• Higher seat pressure than
base valve spring
• 8000 rpm compatible
• Use with cams up to 13mm lift
• Fits 2011-12 5.0L engine
BOSS 302R EXHAUST CAM SET
Part # M-6513-M50BR
• OE Exhaust cams on 2012
Boss 302R race engine
• 13mm lift and 263 duration vs.
11mm lift and 263 duration on
base 5.0L engine
• Compatible with M-6049/6050-
M50BR Boss 302 head
BOSS 302R OIL COOLER
Part # M-6642-MB
• Block mounted oil cooler
used on 2012 Mustang Boss
302S engine
• Cools engine oil as it
circulates through the cooler
5.0L 4V BOSS 302 OIL PAN
Part # M-6675-M50B
• Oil pan used on the Boss
302S race car
• Improved baffling for reduced
oil slosh under hard braking
and cornering
S197 3.73 Rear Axle Assembly
Part # M-4001-SVT373
• 31 spline with LSD differential
• Fits 2005-2012 Mustang GT/SVT
• Incl. finned axle cover
• Bolt-In, requires no special
tools for install
Please call 800-475-7223 and ask for Blake or PM for special Modular Fords Member Pricing
See less See more
