Got the new Team 3 Wheels on. Course we run into some problems as always(why cant things be simple). The front tires needed spacers. Is the backspacing on the front different from the rear on stock?
So we got the spacers on. And took her for a test drive. Didnt happen at first, but then noticed its rubbing mainly when i turned left. It seemed to happen when i was making a turn, and not something like switching lanes. Came back and noticed, there is slight rubbing off on the "C" of Cobra on the brakes and small marks a little on the other side of the caliper. Any suggestions as to what to do.
Should i grind the Cobra down and paint it? New spacers? Longer studs? Will it eventually where it down, to where it wont rub? Get new Rims? Thanks for the help!
:confused:
Im sure you don't. The only other Cobra guy I have met was Jay. I was going to go to the track with you guys but could not make it.
