1 - 20 of 28 Posts
I have 3 sets of pistons for a mod motor. They are:
Your choice $600/set with pins (4130) and locks
1 set of 30002-2
2 sets of 30002-4
Bore Size 3.572
Wrist Pin Size 0.866
Piston Material 2618 Forged
Compression Height 1.220
Piston Ring Size 1.5 1.5 3.0mm
Piston Type Dish -11.5
Rod Length 5.933
Crankshaft Stroke 3.543
9.9:1 with 45cc heads
9.1:1 with 55cc heads
I'm simply looking to recover my money. Pm, or call/text 270-361-8362 Derek
Post was approved by 99mustanggtmqn
I have a stock bore 3V block I am building for my Terminator. So it will have a have a 51cc 4V head on it. What will my compression be?
9.5:1 and you will have to bore and hone the cylinders for these to work. Both sets are 3.572".
That's what I was thinking, open the block to 3.572 since it is at the machine shop already. What block are these intended for?
Any 4.6L block, or 5.4L block. If using a 5.4L block, the pistons will be in the hole .110-.120". In a 4.6L block they will be in the hole .012" or close to it. So in essence, you can use them in any block you want, as long as you bore and hone to 3.572"
Discussion Starter · #15 ·
I have a set of 2V dished and a set of 4V dished. Also a set of 408 LS dished pistons, but I'm sure you're not interested in those lol.
1 - 20 of 28 Posts
