ok so im ready to start up my new motor and now instead of staying all motor id like to run a 100-150 shot,but i gapped my piston rings to a stock spec. with nitrous you are suppose to run more ring gap. to the point will it wreck my new motor if i spray it like that? lots of guys do nitrous on stock longblocks. whats the max i should spray if i can? the car will be running on e85 also.
You'll have no issues, like above stated. I know guys on 200+ Hits, stock long blocks but idk if I'd recommend that. But if you keep it under 200 hit you'll be fine.
