1: I would never even hit WOT until the car is up to operating temp....bad things can happen just from that
2: you usually only need to pull 1-1.5* of timing per 50hp dry or 80hp wet shot.
3: you should be able to tell just by the "butt dyno" which tune you are on (as long as you had a competent tuner)......5* is a lot of timing to pull.
4: I would (if it was me) disconnect the IAT sensor and wire a potentiometer with known resistance values so you can "tell" you engine what intake temps you "want" it to see so it doesn't pull timing and you have a more consistant tune..... but that is just me
