2000 Mustang GT will not start after sitting for 14 days while I was on vacation. Cranks well (Battery good) but will not start. The only thing that I notice initially is that I do not hear the fuel pump run when the ignition is turned to ON. So I do a couple of 10-15 sec ignition ON cycles and still not start. I move on to checking fuses and then on to checking fuel pressure. Fuses are good but I have no fuel pressure with the ignition in the ON position. While I am reading my Haynes manual for the next check, I notice that I left my key in the ON position and now I have 40 PSI of fuel pressure. After two more ignition ON cycles the car starts and runs fine. I let the car sit over night and again no start in the morning. This time still no noticeable fuel pump noise but it only took 8-10 ignition ON cycles to get it to start. Do you guys think this is a fuel pump on the way out? Thanks
