Yes. PD blower are very sensitive to inlet restriction..especially at higher boost levels. Get a big boost kit and a big TB and try more testing.I am still running the stock intake tube. Do you think a JLT intake will allow it to breath easier?
do you have certain sensors or systems that you would suggest to buy and use for this test?Before you spend money on parts buy a couple of pressure sensors and mount them in your intake pre MAF, pre throttle body and one post throttle body but pre blower. Do another pull and measure your pressure drop at the different sensor points. That will tell you right away where the restriction is and you can easily determine what needs to be improved upon.
thanks. i am struggling to search for the user IIRC KBYou are looking for low pressure sensors that can measure 1 or 2 inches of pressure drop. IIRC KB did a complete write up on this sort of set up and posted it up in his tech section possibly with the sensor manufacturer - I can't recall for sure. The alternative is to go down to an industrial supply house and pick up a couple of commercial units.
I knew it would be something simple. Man do I feel stupid.lol. IIRC KB is not a member....
IIRC = If I recall correctly
KB = Kenne Bell
They have a big tech section on their website that Ed is talking about.
Kenne Bell Web Home
