since i have had the blower installed I have found quite a bit of oil in the intake and throttle body. I just put on a k&n crankcase breather, hoping to alieviate some of the problem. PCV appears to be working properly too. what else could be the cause and what are my options and solutions? i have seen pics of some people putting another breather on the intake in place of the pcv.... would this also help?
oil in the intake can be caused by several things. take pcv out of the valve cover and plug vacuum line. sometimes oil is pulled through the pcv. in rare cases i have seen high vacuum cause oil to be pulled by the rings after rings have been used up or over heated loosing tension.
