Getting a code P0234 over boost i have a 2.93 pulley on it but have not driven it yet just idel and hitting the throttle in park. After lookin at the EEC wiring saw pin 45 Super charger bypass soleniod, contol what is the best way to check if it working and coud this by he problem?
Discussion Starter · #2 ·
More Info
The other codes are:
P1229 Inter Cool pump drive (hook up seperate not on the EEC)
P1233 FPDM off line (Fuel pump mannal wired hot with ING)
P0453 EVAP Emissions
P0443 EVAP Contol valve (not hook up, not on the car)
P14515 EVAP vent sloeniod circuit ( not hook up, nit on the car)
Would these cause the over boost code? and will it affect the engine, will this have to be writen out of the tune or EEC?
Thaks for any info getting close to driving it jst need to et the brake hooked up.
All of those codes can be removed by your tuner since I assume you don't have any of that stuff hooked up.
The overboost code usually shows up when the boost bypass is not deleted out in the tune.
I am pretty sure it is all stuff your tuner can take care of.
