1 - 8 of 8 Posts
I have your Dyno runs from No Limit .
Mike said you want them,so Let me know where to email the files.
Nice Numbers!! ;)
Procharger still rules :D
Hey Zesty--
Is that turd of yours EVER going to see the track or are you always full of the Bawwwk bawwwk bawwwks disease??? :shootbird
Jeff
O Well , Mike told me you want them.
But I will give them back to Mike!
thanks
Thanks, maybe you can come out if we make it up that way again. I would like to check out your ride.
later
It's @ No Limit Motorsport now get a Roll Cage.
He should be finish by Wednesday
No track times with F1( Be very soon)
96blkcobra, Just let me know couple advance, I will be there!
A friend of mine ask me to come to a crusie-in next thurday @VARSITY off of Jimmy [email protected] 7 p.m.
Here's Couple of pic
Attn. Chad Brooks
Curious as to what size pulley you were running on your S trim..getting ready to order the reichard pulley and want to know how.. small dia. I can get by with...presently running 3.125 on my s trim , pulling 16 lb.s boost..had s/c rebuilt and was pulling 14 lbs boost prior to rebuild and new idler pulley..also having new idler pulley made by Auto Specialities(better bearings and longer pulley to fit my 8 rib set up..???
Cage looks good. I am sure that one took some time :hammer
Also, I talked to my brother Eric and he was the one that wanted a copy of the dyno numbers, along with the ones for his own car.
1 - 8 of 8 Posts
