Rick, I've had your chip for several months, but delayed before I installed it.
I've received all the power adders that I've chosen for my car, so it's now time to do the deal.
When I ordered the chip, it was for a DC CAI, 2.80, Bass. catback and x pipe.
I've since decided to change directions a little bit by using a BF TB and idler set. Also, I'm moving to a 9" under-hood filter.
Once I install everything, I'll be heading to the dyno within the next couple of days to check everything out.
Does the switch to a different air intake, TB, and 3 idlers make enough of a difference where I should send the chip back in?
Also, I believe that I have the right sized belt, but a little clarification wouldn't hurt ;)
As stated, I'm going 2.8 with a (2) 100mm idlers and a 92mm idler. Am I correct in using the 74.5" GB?
Thanks.
Senior Member
You should be OK a/f but double check any way. With no belt slip and added boost up top it's possible you my need a little more fuel. The 74.5 is the belt I use with this combo.
Rick
