Now that the season is over and my '97 T-Bird is stored for the winter, I wanted to post an update on performance upgrades I made in the last two years. The car has an aluminum block big bore with NPI heads and an SVO supercharger. The motor and trans came back out and the following changes were made during 2010/11:
- New NPI heads with better exhaust port flow
- Custom grind Bullet cams with less duration but higher lift than the previous Comp XE274s
- Blower ported by Steigemeier
- 8-rib belt & pullies replacing 6-rib
- Progressive controller added to the AIS water/meth injection system
- Transmission rebuilt
- Torque converter restalled from 3500 rpm to 3000 rpm
- RWHP increased from 357 to 375, with about 20 HP gain across the rpm range
- RWTQ increased from 399 to 416, with about 20 lb-ft gain across the range
- New personal best ET and speed achieved: 11.959 at 117 MPH
