1 - 6 of 6 Posts
'00 heads on a stock 96 gt engine would make what compression? I have been told 9.7 and i've been told mid 10's. Help on this would be much appreciated
Thank you
i've been looking into the same swap and all the shops have told me from 10.1 to 10.4
I'm looking into this also (put up a new thread last night). From my understanding the '96+ is 9.3, the '00+ motors are 9.74 and swapping the PI heads onto a pre-'99 motor should put you at about 10.5. I've read this in a few articles and wouldn't be suprised. The combustion chambers on the PI heads are much smaller than the stock heads, almost non-existent.
The other thing to consider is the difference in piston dish depth. These varied through the years and through the different applications.
I have also been told that it would go mid to high tens minimum and even into the 11's. However I have recently been advised that the 11 stuff is pure bunk. I dont know for sure though.
10:5 is a good bet some say closer to 10:25 the piston depths did change 96-98 were a smaller dish than the 99+
Mine checked out to between 195 and 205 on each cylinder post headswap. I was close to sea level (South Carolina) at the time and if memory serves the formula yielded approximately 10.25:1 compression ratio.
1 - 6 of 6 Posts
