1 - 20 of 30 Posts
Discussion Starter · #2 ·
Jim, in picture #5 you have what looks like a frame member removed and sitting on a bench. Is that a part that we must remove and have notched to allow the new heat exchanger to sit up high in the front end. So that we can get the added ground clearance? Or does the notched part come in the kit as an exchange or core part?
Discussion Starter · #14 ·
Yeap
Discussion Starter · #16 ·
ALLNTRL said:
Looks good Jimmy! Does it come with the new bumper brace or do you have to cut your original? :confused:
They had one ready..Jdm took mine to get ready for next install..
Discussion Starter · #18 ·
ALLNTRL said:
So if you just ordered one you would have to cut your own brace then, correct? Does it have fans? [/QUOTE
Yeap and no fans,,You could use fans if you want..
So Say BYE BYE to heat soak boys and girls.....I am THERE. Hopefully September 9th, if all goes well.
1 - 20 of 30 Posts
