Building a 4.6 2v for my 03 gt..I have a set of pistons for 97 cobra..Was wondering if i can use them in this build for my gt..
Administrator
Depends on block bore size and piston sizing. In general if they are OEM or used pistons they are best retired and replaced by purpose built / manufactured aftermarket pistons. Chances are better than good the ring lands are both worn and sized for an OEM ring and not necessarily a good choice for an aftermarket performance ring. Additionally the skirts have likely experienced varying degrees of collapse.
About five years ago I worked a deal with Gibtec Pistons for ModFords guys that would produce a set of pistons with tool steel pins, Total Seal Rings, your choice of pin locks and any compression ratio you wanted for either 2, 3, or 4 valve engines. The whole shebang was priced just under $1,200 at the time. Today I think they are between $1,200 and $1,300. The deal is still good today. The pistons are custom billet pistons built in Solidworks and manufactured on multi-axis CNC equipment by Gibtec in Denver. They are likely the finest pistons you can buy for a Modmotor today. Check out this article from the website's articles section Custom Billet Off the Shelf Pistons <= clickable.
Thank you for the info..I believe ill save up for some and as luck would have it i just got another complete gt engine for free..Though i did have a 2 hr drive one way to get it ..They kept saying it was a 02 motor but it had 21 # injectors the same as my 03..I thought that only 03 and 04 had the 21# and 99-02 had 19#..Anyhow i think i can make this one work while i save to build my project motor up..Thank you again for the info and sorry it took so long for response
