The Plasma Booster has shown me Mixed Results..At Larocca's on a 99Built Cobra approx 575rwhp it showed about 10rwhp.
On my built 99GT approx.600 rwhp it also showed similar results..
I have seen on Stock or lightly modified Modulars and 03 Cobra's It does not show these gains.
In my opinion like an MSD on a Pushrod the added Spark will only help if needed.
Any other experiance or opinions welcome..!!
Snake Charmer
Its only supposed to add about 1% power so the 10hp increase isnt bad. I think to properly gauge its benefits you should time how long the car takes to get to peak rwhp. If it can shorten that time frame due to a more efficient combustion then you should see the benefit at the track if not on the dyno.
If I understand the product correctly, the Plasma Booster is an upgraded ignition box.
Let's not forget that there are benefits to an improved ignition system beyond increases in horsepower. They ensure proper spark is there when needed under heavy load.
If it smoothes out the power curve up top, I would consider it a worth-while investment, even if it doesn't show any significant gains.
That's what the Kenne Bell Boost-a-Spark has done for my 03.
