These are the codes I pulled from the motor today. I need help on specificly what they mean/why it popped, how I can fix them, and if they are contributing to my poor drivability (car studders like CRAZY during normal driving). These are the codes:
P0750 Shift sol A fault
P0755 Shift SOL B fault
P0743 TCC System electrical fault
P1401 DPFE CKT High voltage
P1409 EVR CTRL CKT fault
P0605 Internal CTR module rom error
P0713 Trans fluid temp sensor high input
P1127 HO2s Downstream not tested
P1101 MAF Sensor out of range
P1780 Trans control switch out of range
Here are some other things I noted that I need an opinion on:
LFtrim 2(%) 22 SF trim 2(%) -1
LF Trim 1(%)9 SF trim 1(%)0
Now I think the transmission codes are because I have a manual valvebody so the computer has no connection with the transmission. I also have no cats so that would explain the o2 code I think also but the rest I'm at a total lost and my car is running like total SHYT. Here is a list of my mods:
97 GT auto conv, Vortech (14psi), 4.10 gears, Flowmaster, Off road h-pipes, FRPP headers, Autologic chip, MSD dis-4 ignition, MSD wires, Accel coil packs, 70mmT/B, 90mm MAF, Power pipe, forged pistons & rods, MSD tach adapters, 3000 stall torque converter, K&N filter, BBK fuel regulator, Walbro 255 in-tank fuel pump, FMU, B&M tranny cooler, Performance Automatic manual/transbrake valve body, Race P&P non-P.I heads, SHM Cams, Spearco Intercooler, Race B.O.V, 42lbs injectors, T-Rex Fuel pump, 2.87 Vortech pully, Steeda springs, 99 Polish Cobra rims 17's, Autometer Monter Tach and boost gauge
All opinions and advice is well apreciated.
-Ray
I'm not sure exactly what those codes mean, but maybe ford does?
02 t5 huh how did you manage that with a special bellhousing??? I just bought a tremec out of a 02 gt to put in my 96
