1 - 7 of 7 Posts
ok i'm gettin 1 tire fires....anybody replaced their posi...and which one did you use...yes i know ford uses trac loc same crap limited slip whatever...
For some trips to the track, I would say an Easton Posi 31 Spline, new 31 spline axles, a girdle and your set for slicks. The Easton unit is very streetable too. If your a hardcore Drag Racer get a full spool with C Clip Eliminators.
Go do some crazy 8's and that will fix your one leggers :)
Re: well...
R. Stinchcomb said:
...I run a "stock" Ford trac-loc in my car, just shim the clutch pak a little tighter and the kit is only @$55.00
Randy
where did u get that kit from?
1 - 7 of 7 Posts
