1 - 5 of 5 Posts
I'm thinking about adding a power pipe to my Novi 2000 setup on a 1999 GT. Will I need to re-tune after adding this?
I'm currently running the Paxton supplied tune and exhaust mod's and I'm seeing 380 rwhp. The tune is very rich.
The BarTender
Typically you will see about a 2lb boost increase with the power pipe. I would at least suggest having the car on the dyno with A/F readings at minimum. If it's lean then re-tune it, if not then let it rip!
Razor.
1 - 5 of 5 Posts
