Are the pressure plates different between a mechanical and a hydraulic throwout bearing? I'd like to run a mechanical throwout bearing on a new model pressure plate and I'm not sure if it will work.
Discussion Starter · #2 ·
If I measure the height of the fingers on the 2012 pressure plate they are 1/4" taller or farther back from the flywheel, compared to an older pressure plate I have. I could be wrong but shouldn't I be able to adjust any differences in this with the clutch cable as long as the throwout bearing fully releases?
I've looked at pictures of an 11" 01 mustang pressure plate and it looks very similar to my 2012 mustang one.
ok thanks I think for the price of a clutch disc worth a shot compared to new flywheel clutch pressure plate etc. Just have to decide between an 01-04 disc or a 2005 -10 disc, both are the 10 spline I need for my cobra t-45. Only .02" difference in diameter 11" vrs 280mm. 04 disc looks like wider friction area on disc than the 2012 disc and the 05-10, think I may flip a coin on which one to try first.
Discussion Starter · #7 · (Edited)
I don't think mixing and matching discs and pressure plates is a good idea. Use the disc that belongs with the flywheel and pressure plate.
Cant do that flywheel and pressure plate is the 9 bolt from the coyote. disc for that combo is a 23 spline I need a 10 spline disc like in the 2005-2009
When I talked with FRPP rep said it would work for a newer trans but stack height would be off for older trans.
So only other option is to get a new flywheel, clutch and pressure plate. I figure if I get a take off clutch disc from an older mustang the 8R3Z-7750-A and measure against the disc I have. I only $50 to risk.
Yeah thanks for all the help I know best way to go would buy a new flywheel and then just buy a new clutch and pressure plate but that's around $400. I already have two coyote flywheels both take the 9 bolt pressure plate. I also have a almost brand new clutch and pressure plate off a 2012 sema build mustang less 500 miles if that. The 2012 clutch disc is a 23 spline, I have an older 10 spline trans out of a 98 cobra (has better shifter position for me and at time of purchase was originally going behind a 4.6 4v), so I was going to try and use a 10 spline clutch disc with the 2012 pressure plate, as it would bolt to the flywheel I have now.
