1 - 13 of 13 Posts
Call me nuts but I can't seem to get the lower exhaust manifold bolt loose on the passenger side of my car because of a lack of room. I am trying to install some prochambers and got every other bolt loose except the above listed one. I even broke down and had a mechanic try with no luck. Is there a special tool needed to reach that bolt? I have just returned home from Iraq and all I want to do is put that damn part on my car. I know that it's not impossible maybe I'm just too dumb. This is making me sick.:vomit: Thank you for your help
How did you make out...How does that Prochamber sound??
I never got the damn thing on. I tried for over two hours to get that last nut loose with no luck. I know that it is not impossible to do because several '03 Cobras have prochambers on. Is there a special tool needed to get that last nut loose? I even went to a Midas shop and I was told that they wouldn't install the prochambers because it would be against the law. I should have stayed in Iraq!!! I would appreciate any advice that you could give me because I am going out of my mind.:shocked
Only Advice i can gove you..Is to find a Performance shop to do it..You need a Power tool..
Thanks, I'll find a performance shop tomorrow.
Call,,,Mac..for the closest Mac Dealer near you..
MAC it is. I hope there is one near Fort Benning, GA.
Go to Tifton Ga.. Chad and Eric who run this site will hook you up..:D
By the way,,Thank's for Serving in the Armed Forces:) :)
We have installed a jillion X pipes, H pipes, Prochambers and the thing we found to work best is a 15mm 6 point deep well socket with a 1/4 of the length cut off this along with extensions and swivels and of course as Jimmy V. said an impact makes the job as snap! Good Luck!
Thanks for the good advice. I'll make it happen.
Hang in there..These cars are worse then Broads,,Always a Problem;)
Discussion Starter · #12 ·
All I wanted was to get rid of the cats and get a little more growl out of the beast not an ulcer. Thanks for all the advice I'll use it. And no, I'm glad to be back in the good old USA
Using some heat from a torch may help too. Don't burn your car down though :)
1 - 13 of 13 Posts
