I'm having issues with the turn signal wiring. On the wiring diagram it has left turn signal head lamp being light green and white wire. For the right I thought it was light blue and white wiring. That has proven to be incorrect as it causes my hazards to come on. And the rear tail lights stay lit up. I was told that it was light brown and white instead but unfortunately I don't see a LB/W wire by the gauge cluster set. I a harness from an 03 Mach 1 and ecu. This is the biggest thing that is holding me up at this point.
