$450 shipped
3 inch thickness, 3" tube diameter. 27 x 15 x 3, rated to 950 HP
More specs can be seen here
http://www.procharger.com/intercoolers.shtml
This is an expensive intercooler, over $1200 new.
lightweight, only 26lbs.
This intercooler was recently rewelded, but now is ready to go. I leak tested it to 20 psi and it holds solid. The horizontal bars on the bottom are extra braces I had welded on to prevent flex in the tank walls.
Could you please email pictures to [email protected] I can't see them on here at work. I'd like to see pictures of where it was welded, do you have any pictures of the damage that required the welding? I'll be pushing more then 20psi through it, so I want to make sure it will hold beyond that.
Sure, I'll send you the photos today.
