1 - 8 of 8 Posts
put the kenne bell on today...not too bad...took most of the day..have a few question if anyone can help..kb's store is closed so i cant call............throttle cable seems real loose but if i manually put a little pressure where it connects to the throttle body..idle goes down..also have a small amount of gas seeping from around the bottom of one injector tweaked with the actual fuel rail a little bit..i thought maybe if it was a littl bent that would keep the injector from seating all the way in??? car starts right up just the idle problem......tommorow the boost a pump goes in and monday hopefully pat at diablo will tune it!! car has 3" mac exhaust and longtubes...curious what power it makes..have a 2.7 and a 3.1 pulley....thanks guys and help appreciated...mike
What throttle body, mike? Sounds like either TPS voltage is too high or you have a mechanical problem with the TB.
throttle body...where the cable end attaches to the ..sorry dont know correct name for it.....piece on the side of the throttle body..where the cruise cable also is attached..if i hold that in my hand while the motor is running and turn a little bit..the idle goes down..you would think the cable is pulling on it but in fact the cable is very loose
Like Hammer said..check you Throttle Position Sensor's volts. I Have a thread on this site somewhere that states how. Then mod it if you have to ,accordingly.
Also try disconnecting your cruise cable and see what happens.
Hot Rod(I am a great backyard mechanic..but I am leaving my KB install for the professionals like Nitrous Pete)Harry
Make shore you fix the fuel leek, the o ring may have rolled over a tad. Take it back out and installit with vasoline, If you have a throtel prob. call me to explane, nitro
All Mustangs have slack in the throttle cable. You can easily tell by pulling on it at the top of the gas pedal. Mine had about 3/16" slack.
The mod is to use a zip tie or some type of spacer to take up that slack at the pedal. Supposed to improve throttle response a lot. Some cars have so much slack that the TB doesn't fully open before the pedal hits the floor. Not good. I'll get around to it fixing mine one day..
thank you much.....hot rod harry wins the right answer award...cruise cable was pulling a little too much...easy fix
Good to hear it was something simple. Keep us up to date with the new found POWER!!!!!!
I CANT WAIT FOR MY KB!!!! I WANT IT NOW!!!! :D
Hot Rod(I hate to wait)Harry
www.HotRodHarrys.com
1 - 8 of 8 Posts
